Does anybody know the binary format of datalog files? We have used the datalog function to write binary data to a file, and would now like to read that data directly in Igor or C. I think we can decode the binary data itself, based on LabVIEW's documentation of binary data formats, but there is a header on the file that we can't find documented.
A search revealed the same question from a few years ago, but the answer was insufficient. It also revealed a similar issue for reading "datalog" files generated by the high-speed datalogger example, but those aren't true LV datalog files. They are binary files with a custom binary header. Also, some messages discussed the front-panel datalogging function, but that is not what we are after. We are using programmatic file writing, with the datalog file format.
Dave
