How to read HMC 5883 Magnetometer
im using hmc 5883l sensor to read the magnetic field in 3 axes x,y,z.
i used arduino to get the output and i got the output. now im trying to interface arduino r3 with labview and get the output but im not getting any output. i have attached the vi which i used . i don't get any error but there is no output at all. please help me with this.
(1,922 Views)
Hi Ramson,
Which one of the VI in the folder do you refer to? There is a Read Data Example VI that doesn't have the reference to the Arduino board when you initialize the configuration.
Also, have you tried to run a simple blink LED example just using the board (pin 13)? This will allow to verify and set the correct interface between LabVIEW and the Arduino and we can then move into the test with the sensor.
Cheers,
Rob
(1,867 Views)
