04-20-2016 09:32 AM
Hi guys,
I'd like to reach Packed Libraries Dependencies in order to know if the Packed library i am building is calling another one.
Any hint will be apreciated.
BR,
Vincent
04-29-2016 05:21 AM
Hi Vincent,
Were you able to find the answer by yourself? I am not sure I understand, don't those dependencies appear in your project?
Junior
04-29-2016 05:34 AM
Hello Jun,
Thanks for your answer, was feeling lonely 😉
One project is architectured with Multiple Subproject which are build in PackedLibraries.
The Main Project (corresponding to HMI) is calling VIs from multiple subprojects.
Today i know which packed library i have to build first and so on but i want to do a build auto which detects what is the build order.
Since i didn't get any answer, i wrote manually the build order in a BuildOrder.ini 🙂
Do you undersand a way better my need ?
BR,
Vincent
04-29-2016 07:14 AM
I've found this document, I don't know if it helps or not?
04-29-2016 07:23 AM
Hi Jun,
Thanks for this document but what i am looking for is a way (by property nodes/invoke nodes) to get PackedLibraries dependancies.
Meaning open each project and check if current project dependancies need another PackedLibrary to build.
BR,
Vincent
