06-21-2019 05:12 AM
I have a main program, and I have a button on the main program that opens two vi's simultaneously. The problem is that both VIs literally open one on top of the other. I would like them to open simultaneously side by side. Is there a means of accomplishing this?
Solved! Go to Solution.
06-21-2019 05:26 AM
06-21-2019 05:27 AM
Yes. There is a Property of the Sub-Routine called "Window Run-Time Position" (when the sub-routine is open for editing, right-click its icon, "VI Properties", "Windows Run-Time Position"). Use the Help button if it isn't intuitive. Note you can also position the two Front Panels "manually" and choose "Unchanged", which can also work (I think).
06-24-2019 05:44 AM
Yep, this helped. I just went to the VI's Properties menu and found just what you're talking about. It was easy! Thanks.
