01-13-2021 01:23 PM
01-13-2021 02:49 PM
Do you have the Vision Development Module? Without it, you can use the Draw Point.vi, as shown in the next VI snippet (to use it on your VI just download it and drag and drop into the block diagram).
With the Vision Development Module it should be easier, first creat an image, and then use the pixel manipulation VIs to modify the values according to your matrix and display the image, but I am assuming you don't have it.
01-14-2021 07:35 AM
what is the name of this control funciton
01-14-2021 09:39 AM - edited 01-14-2021 09:41 AM
That is a bundle, you can find it under the Cluster, Class, & Variant VIs and Functions palette.
