09-17-2007 03:11 AM
09-17-2007 01:11 PM
If you use "append table to report.vi" instead of "Word easy table.vi" you can append a table at a bookmark. First you have to make a word template with the boomarks you are going to use. Look at the appended example, in this example I use a template called c:\temp\lvtable.dot and a bookmark called LVtable.
