07-20-2017 04:48 AM
Hey everyone,
I am trying to use this method, and it wants a NULL to query all.
What do I wire into workspaceName? Empty String ("") does not work, just a constant with no characters inside does not work. Creating a byte array with 0 and converting to string does not work. With "does not work" i mean i get an empty array of workspaces, just like when i enter a notexisting workspaceName. I do not get an exception.
The method is working when entering an existing "workspaceName" into the input.
Thx in advance
Solved! Go to Solution.
07-21-2017 04:58 AM
you cannot send a NULL with LabVIEW directly. If you absolutely need that you would have to create a wrapper DLL, that sends the NULL and you call the wrapper DLL instead of the original .NET DLL.
Christoph
07-24-2017 01:27 AM
OK, thanks for the answer. As this is an absolute standard .net method from Microsoft, can this be implemented into LV or does any internal data handling prevent that entirely?
07-26-2017 02:47 AM
For future use or other users:
With System.String (in mscorlib) there is the static property "empty" which works perfectly.
12-06-2018 01:20 PM
If it is for database related, you can try with "DB Tools Null" function (Connectivity->Database->Advanced).
Sanad MM
