How to open/run labview by press button in microsoft excel?
Dear all,
I have another problem related to EXCEL.
Now, i want to run my labview by press a button in excel. I'm not sure is it possible to create a press button in microsoft excel?
When i press the button in excel, it will trigger, open and run the LabVIEW software.
Is there any related forum or example i can refer?
Thank you.
(2,503 Views)
that is an excel problem .. you should search for it in *search engine*
e.g. https://stackoverflow.com/questions/20917355/how-do-you-run-a-exe-with-parameters-using-vbas-shell
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(2,496 Views)
yes, it's possible. you must active the developer mode on EXCEL to do that (using VBA in EXCEL).
active developer mode
@GavinT
Use the command shell for it. example
Kudos are welcome!Smiley Wink
(2,479 Views)
WHY would you want to do this?  You are going to start Excel, and use Excel to start the LabVIEW Development system by pushing an Excel button?  This sounds totally weird and a potential Recipe for Disaster ...
(2,431 Views)
I'm curious about your reasons too , why do you want to do that?
My Channel: https://www.youtube.com/@LV_Lab
(2,424 Views)
Me too...
Also you do know that if you have a spreadsheet open in Excel you CAN NOT open the same spreadsheet in LabVIEW because Excel will have the file locked and you will get a sharing violation.
=== Engineer Ambiguously ===
(2,408 Views)
