How to open an CWgraph3D object in word if labview is not installed?
I want to export a CWGraph3D from Labview to Word. Actually, it is working pretty good in my computer, but once I try to open the word file in another computer that doesn't have LabView installed, it just open the graph as an image and  I can not be able to rotate the image or manipulate the graph.
Do I need to install the MStudio drivers or any other driver necessarily? Is there any other way to do it with out installing LabView or any other driver?
(2,686 Views)
The CWGrpah3D object itself cannot be opened dynamically if LabVIEW is not installed. You can save an image of the graph and then put that in Word. Would that help?
Ipshita C.
(2,663 Views)
