How to obtain match score for the image, from vision asssistant
I was doing a little research, and a question came to mind.
Is there a way to get the match score for the image being analyzed, with the vision assistant?
I think there's a way to do this, but if I generate the source code, from the vision assistant, but I wish to keep using the assistant, because its much easier to edit.
So if anyone can show me how to do this, I would really appreciate it.
Thanks.
(1,922 Views)
Accepted by topic author Nando88
I just found the answer.
In the vision assistant, you have to drag down the bottom part of the assistant, to display more output. Then you need to unbundle by name shape detection or match pattern variable, to get the matchscore as an individual element.
(1,890 Views)
