I have a small problem, every time I insert a element with multiple elements in the xml file, xml version is inserted each time, and I want to remove that, but I didn't find a solution.
Can you please give me some ideas on how to do it?
I attached the vi's(one is a helper, actually my VI is based on the XML Parser exemple from Labview exemples) and a screenshot with the result.
Thank you.
