05-24-2006 06:58 PM
05-24-2006 07:05 PM
05-25-2006 01:50 AM
Other than using the previous suggestion (followed by Byte Array to String, or course), you should consider whether you want to complicate your code and spend processor power on doing this just to save bandwidth.
LV allows you to do communication protocols extremely easily by providing VIs (in the advanced palette) for flattening and unflattening any data to and from a string. If you search the example finder for "TCP" you should find some examples of this. Also, if you search the site for "messaging protocol" you should find a good tutorial about this.
