04-08-2009 02:54 PM
04-08-2009 03:25 PM
04-08-2009 04:04 PM
Thank you!!! that was a huge help. I don't think I need the case structures at all. The next part of the code compares the 4 values in the array.
If columns 0 and 1 are both positive -> output 1
If column 0 is negative and 1 is positive -> output 2
If columns 0 and 1 are both negative -> output 3
If column 0 is positive and 1 is negative -> output 4
(0 is x-axis value, 1 is y-axis value.....outputs are assigning quadrants to the combination)
Only one of the "AND" booleans will return true for each index. Is there a way to initialize another array of outputs 1-4 depending on which AND returns true?
04-08-2009 04:04 PM
04-08-2009 04:35 PM - edited 04-08-2009 04:36 PM
