09-23-2007 10:31 PM
09-23-2007 10:40 PM
Note This option is disabled when you add a splitter bar to the front panel. You must configure the panes individually by right-clicking the pane and selecting Pane sizing»Scale all objects to pane from the shortcut menu. |
09-23-2007 11:15 PM
Thank u so much for ur reply sir.
Yes i am using splitter bars in my application.
Just nw i tried the options in a simple vi with a multicoplumn list box only.But sill its not giving desirable effects when the resolution is very high.I read that v can programatically set the resolution when the vi is running and set it back to original resolution after the completion of the execution of the vi.
Any help regarding this?
Or can suggest me a work around for this issue?
Thanks once again
09-24-2007 03:21 AM
09-25-2007 09:03 PM - edited 09-25-2007 09:03 PM
Message Edited by Bill@NGC on 09-25-2007 07:04 PM
09-26-2007 04:54 AM
Hi
Thanks for the information.
I will try this method
