03-02-2006 07:33 PM
03-03-2006 03:21 AM
03-09-2006 07:34 PM
Dear Paolo and all,
sorry for getting back so late and thanks for your modification. i got clear with my second request (resetting the stop button) but i couldnt understand how the modifications you made with the first request will help me. nevertheless i tried to run the program but it doesnt work. may be i didnt say my request clear. ok, here u go i try again.
in the attached vi, the program loads an xls file, which has about 245000 data points, then writes it every 1000 datapoints/sec, starting from data point 1. i used 'delete from array vi' and you used 'array subset vi'. i appreciate the way you got rid of the shift registers. but my question is, once all the data points are written, how could I start to write from data point 1 again, without restarting the program. is it possible?
hope i explained clear this time. may be u already tried to resolve the same issue with ur previous modifications and i didnt understand. if thats the case, can you please explain what i have to do? i tried to run the program with ur modifications but it stops once it wrote all the data points.
many thanks.
Rishe.
03-10-2006 02:28 AM
03-17-2006 01:12 AM
Dear Paolo,
thanks for your advice. i think i understand what u said. well not exactly. but i think thats ok. can i ask you one more thing if thats not too much. in the program, u can see the read and write vi are in the loop and the loop runs for every second (1000 data with a sampling rate of 1000). so the display i am looking at updates only every second. If i want the display as a scroll type in waveform chart, in other words, the display should be continous like a stream, then what is the best and easy way of doing that?
thanks a lot mate.
Rishe.
03-17-2006 02:11 AM
03-21-2006 07:01 PM
03-22-2006 10:15 PM
