How to make my own device driver visible in MAX?
Hi all,
i created a piece of hardware for the PC which i want to
make usable within LabVIEW.
- The hardware is Non-NI so there is no matching device driver
available from NI.
- I want to reuse all the existing instrument drivers (VISA)
without modifying inside these.
- I don't want to access the hardware using direct dll-calls.
- I only want to do this: "Hey VISA-object! Don't talk to this
GPIB-card inside my PC. Communicate with my hardware" 😉
So i need to write my own low-level device driver (NOT
instrument driver) which integrates in MAX.
But how to do this?
Any useful hints how to start?
Is there any open source project for Win32 i may modify for
my own purposes?
TIA.
Regards, Thorsten
(3,038 Views)
Thorsten:
If your card is PXI or PCI, then you are in luck because NI-VISA will help you. Otherwise, you cannot show your instrument in MAX.
To use NI-VISA for PXI, just get your register description manual from the vendor and follow the instructions in this paper on our site:
http://zone.ni.com/devzone/conceptd.nsf/webmain/ADF3152837E2B4A486256B5600642AC7?opendocument
Good luck,
Dan Mondrik
Senior Software Engineer, NI-VISA
(3,038 Views)
