How to make front the panel transparent while certain control still visible?
I'm trying to make a countdown vi as attached. I want the whole thing to be transparent with only the number visible. However making the FP transparent means every controls/indicator will be transparent. So how to leave certain control/indicator unaffected? Or are there better ways to do it?
Lei
Message 1 of 24
(7,452 Views)
You can make a specific color in the front panel transparent if you don't mind making a call to the Windows API. I posted an example here, but I believe in that case it's using a constant for the color. You can get the details yourself by reading the function's documentation in the MSDN.
___________________
Try to take over the world!
Message 2 of 24
(7,443 Views)
Wow, it works!
Andrey.
Message 3 of 24
(7,431 Views)
Hey Andrey,
    Can you save it in 8.5?
Lei
Message 4 of 24
(7,422 Views)
saved for LV 8.5
Message 5 of 24
(7,413 Views)
Amazing! Though absolutely no ideal how it works! Never dealt with API so far. Need some research ...
Thank you both!
Lei
Message 6 of 24
(7,399 Views)
it really really amazing thing. so cool app. i just try to do this thing. thks "Andrey Dmitriev" for post it here.
Message 7 of 24
(7,256 Views)
Andrey,
Can you attach it for lv 8.0?
Message 8 of 24
(7,112 Views)
muks wrote:
Andrey,
No, sorry, I haven't 8.2 on my PC for downgrade.
Here is the screenshot:
The main idea is to make front panel completely white, and then using white as color key for transparency.
Andrey.
Message 9 of 24
(7,105 Views)
Here's the VI in 8.0. For those who want an earlier version, you can just open the example in the thread I linked to earlier.
The input which is 00FFFFFF in the example is what the determines the transparency color. FFFFFF is white.
___________________
Message 10 of 24
(7,108 Views)
