How to make file folder structure from virtual folders
lv 2013 sp1
This is the layout of an example project, (please don't mind the horrible naming)
When i create a source distribution.. no matter what settings I try, the preview is always like this:
But I want the folder structure from the build to become as the virtual folder structure. is there any way of doing this without moving them by hand in the file explorer tab?
(2,543 Views)
Unless you use auto-populating folders (which I don't like), the virtual folders are not meant to reflect the location on disk, so it certainly won't be automatic.
I don't have experience with source distribution, but other build types have the option of configuring destination folders in the Destinations category and then assigning these destinations to items in the projects (including virtual folders, which then takes all the elements inside it) either in the same category or in the one under it, I can't check. I expect that you can do the same in a source distribution.
___________________
Try to take over the world!
(2,540 Views)
could you please provide an example of this, I only see three options, "Destination directory", "same as caller" and "Support directory".
(2,531 Views)
Accepted by topic author mersdal
When you go to Destination you can see " + " and " - " symbol at the bottom of the list box, you can use it to add folders. Then go to the Soource File setting and do the addition settings.
(2,528 Views)
Thanks, it is not automatic, but really saves my ass in organizing the files on disk. I did not see that button before.
(2,522 Views)
