How to make cluster element global
In the VI i'm using a cluster with 1 array and 4 controls and one of the control i need to use as global in teh entire VI
How can i do that?
(2,647 Views)
Hi Padma...,
do you need this control in several places in ONE vi or in the WHOLE project?
If it's just in the vi, you can use a local of the cluster and get the value of the control where you need it - or just use a wire instead.
If it's in the whole project, you can make a global and copy the value of the control to that global, whenever it changes...
If you would be more specific, then we can make even more, better, detailed suggestions 🙂
Message Edited by GerdW on 12-11-2006 10:38 AM
(2,642 Views)
This is probably related to this post.
(2,615 Views)
