BigBug,
I wrote an example in LabVIEW 6i, if you have a different version of LabVIEW let me know to save it in that version. Basically I want to point out something about the Text Ring Control, the value it has is only number index, and it starts from 0 to over... anything that you put inside the Text Ring is not what is transfer to a multiplication, string, etc... imagine that a Text Ring Control is list of names like mine Nestor and Sanchez, so you have two items, well, for the Text Ring you have item 0 and 1... not Nestor and Sanchez... if I had add... National Instruments and after that LabVIEW... then they will have position 2 and 3 respectively. So when you perform operations with Text Ring the value it will pass is the index number of the position select
ed, not the value written to it.
In the example I wrote for you you may notice in the block diagram how did I selected the exact value written in the Text Ring to be multiplied by the factor you want. Is just a matter of having a case statement with the different positions of the Text Ring, and the when a position is selected you have a constant value inside the case statement, which is the one that is going to be multiplied.
Hope this clarifies this point,
I appreciate the help from the previous person who answered this email, this VI may also be of help for him to complement the VI he placed here before mine.
Good luck!...
Nestor Sanchez
Nestor
