Hi
There are a Couple of methods you can use for this.
Method 1 -
You can create an ini file and save a boolean Key "First Instance" as True. Now In your Program you read this Key, If it is True then you can show your ID Dialog VI.If False do not run the VI. At the Conclusion of Id Dialog you can update this registry enrty to False. So In effect you have created One time Event. In fact you can save ID as another Config entry.
The Drawback and advantage is that such an INI file can be edited by someone moderately knowledgeable about the Program
Method 2
Use Unitialized Shift Register in A while Loop. Please see LV2 style Globals entry under this forum. You can read and write to this Variable and it retains the Value it last had within it.
You can read
this Global the Very first time and say if it true you display your ID Vi. If False you dont. When you display your ID Vi you can Update your Global Like Before.
If you need Example Let me Know.
Good Luck
Mache!!
Good Luck!
Mache
