How to make a graphic using joysticks
we want to do something like this but with a joystick and labview 2012 without using NXT:  http://www.youtube.com/watch?v=xpKRf923z3k
(3,451 Views)
What have you done so far? Are you using the joystickAcquire function?
(3,398 Views)
What joystick?  Windows or Mac? (I probably can't help with Mac).  What have you done so far?
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(3,388 Views)
Hi carlosm27,
In the Connectivity Palette LabVIEW has VIs to initialize input devices like a Joystick, Keyboard or mouse. You can use this VIs directly in your project. I Share with you a link with information about that and a reference to LabVIEW examples.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/computer/plat-inputdevice...
There it is an example using this VIs
http://www.ni.com/example/30510/en/
Also you can use the NI-VISA driver to control different devices with their own drivers. Here is an example
https://forums.ni.com/t5/Example-Code/Logitech-Attack3-Joystick-LabVIEW-Front-Panel-Control/ta-p/351...
Its important to know what kind of joystick you are using, the LabVIEW license and your Operative System.
Hope this information Helps you
Regards!
Omar I.
(3,368 Views)
