Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
How to load a VI into a dynamically selected SubPanel?
I would like to dynamically select a subpanel for which to load a VI into.  I modified the LabVIEW Help example "Multiple VIs in a Subpanel.vi" to illustrate my issue.
I understand the static example.  It works fine.
I have a situation where I have several subpanels and a number of Plugin VIs.  Here is an example of how I thought I might be able to code it.  What is wrong?  I understand this may be pushing scripting a little bit too far.
A fall back is to use explicit instead of the implicit Insert VI Method.  But that is not as elegant of code and not as scalable.
(1,875 Views)
Accepted by topic author Mark_L
Your code has the VI trying to edit itself.  Which is not allowed.
The "Create.Control Ref" method creates a reference on the block diagram of the VI that owns the SubPanel (which is itself).
Try the attached VI instead.
(1,835 Views)
Your example VI works.
I understand now and I thank you for your explanation.
(1,789 Views)
