09-06-2005 10:24 AM
09-06-2005 10:54 AM
09-06-2005 10:54 AM
09-06-2005 10:55 AM
Blog for (mostly LabVIEW) programmers: Tips And Tricks
09-06-2005 12:21 PM
Short Name: DevNames
Property of DAQmx System
Indicates an array that contains the names of all devices installed in the system.
This returns all device names without making an assumption about naming conventions such as Dev1 to Dev6. daqMx allows for naming the device with meaningful names through MAX. I would encourage using daqMx, I found it a large learning curve over traditional DAQ but was well worth the time. I would also assume with DaqMx there will be a phase out of coding using traditional drivers over the next several years (I could be wrong about this) .
Paul
09-07-2005 02:32 AM
Thanks for your help everybody !
Olivier
