How to keep the ring's item enabled?
Dear All,
There is a ring in my vi, when I click some buttons, some items of the ring will be disabled.
How to do that, when the item selected is disabled, the other item which is not disable will take place of it automatically?
Thanks.
(2,611 Views)
Try this VI for disable the selected item in the menu ring.
by,
Kumar.
(2,608 Views)
Try this VI for remove the selected item in the menu ring.
by,
Kumar.
(2,603 Views)
If you know in advance which are the items are enabled, then pass the index of the enabled item that you want your ring control to indicate, to a Ring property node>> property "value ( signaling)"
(2,602 Views)
