How to interface with Chameleon camera
Hi everyone,
I am trying to use Labview to control Chameleon camera, which is from Point Grey Research. I am using the ActiveX control interface and I have encounter a problem of using "Call Library Function" node. I am using that node to get the image array from a pointer and trying to display. However, the "Call Library Function" node doen't work.
I am wondering how can I get the  image array from a pointer that is used by the FlyCapture?
Was there anyone experience the same thing?
Thanks.
Carson
(3,032 Views)
CarsonZ,
Please check to see if your camera is supported by the Industrial Camera Advisor. Also, when you say that the Call Library Function node does not work, does it return a specific error message or just not return any data?
Lastly, is the FlyCapture application an ActiveX enabled application? If so you should be able to register for events and also pull the information from the application by running through this help document.
Logan H
Applications Engineer
(3,006 Views)
I've checked the Industrial Camera Advisor and the Chameleon camera is not there. I think that might because Chameleon is a USB camera. FlyCapture application is definitely an ActiveX enabled application and I have successfully used the ActiveX to control it, it is just I cannot poll out 1D array image date from the pointer using Call Library Function node. Is it possible that my dll doesn't work because it doesn't support 64 bit Win7?
Thanks.
(3,000 Views)
