09-02-2017 12:42 PM
I need to know which interface is available to communicate the instrument through. I need to design an application to acquire the spectra.
The problem is there no interface available at all.
Need help!
09-02-2017 02:53 PM
What is the model number of the instrument?
Didn't you answer your own question? If there is no interface available, then what are you asking for?
09-04-2017 01:34 AM
I've used one of their SpectraPro models, and there's an ActiveX automation interface that can talk to the software that controls it.
If I remember right I think I had to contact their support department directly to get a copy of their software that worked with Windows 7 and ActiveX under LabVIEW. It might not be something you can just download.
11-03-2017 08:14 AM
I am using WinSpec 32 2.6.24.0 version and trying to communicated it through labVIEW using Active X control. Earlier I Could communicated using the Active X in window XP but I not able to achieve the same task in windows 7. Please help me with this problem !
11-03-2017 08:21 AM
11-03-2017 08:44 AM
Sounds like you should be talking to Princeton Instruments not us.
11-03-2017 08:45 AM
Talk to Princeton Instruments.
Don't post the same thing twice and waste people's time.
