How to install the 32 bit version and the 64 bit version of lab VIEW 2014 SP1 in the same machine?
Well, if it is so, I apologize for what I said.
Regards!
Once for all!
Message 11 of 15
(1,092 Views)
If you have a 64-bit version of LabVIEW and Application Builder, can you create an executable that's 32bit?
Message 12 of 15
(971 Views)
No .  You need LabVIEW 32 bit to create a 32 bit executable.
Message 13 of 15
(956 Views)
Yes you have to use the 32 bit Lab VIEW for that, even its better use the 32 bit version, well in my case i use linx with my Raspberry Pi and only the 32 bit version work with that, even that... why you want to run a 64 bit version in a 32, what proyect are you doing? well if you have another question here we are in contact
Message 14 of 15
(950 Views)
Thanks for the reply.  That's what I was thinking but wanted to confirm; since there were no options for different OS installs inside the builder.  I'm working on an existing project that was built in 64-bit version.  I needed a 32-bit executable for folks who were running an older 32-bit OS.  Thanks again for the reply.
Message 15 of 15
(948 Views)
