How to insert new data after every iteration
Hi All,
Looking for an idea.
I am writing a text file where a certain part is repeating, therefore I am using For loop to generate the same part for n number of times. I would like to know what is the easiest way if one wants to change tiny information between the iterations.
for example: This is what I want to write in the first iteration
Kind: Transmission
Angle: 0.000000
Polarization: 90.000000
For second iteration:
Kind: Transmission
Angle: 0.000000
Polarization: 50.00000
and so on.
One way could be to have the same information for n number of times and then used search and replace function. I think this would be quite time consuming and prone to errors as will have to use search and replace function for n number of times.
Hassan
(98 Views)
Accepted by topic author HassanIqbal
Use format into string with this message as the format
-Santhosh
Semiconductor Validation & Production Test
Soliton Technologies
NI CLD, CTD
LabVIEW + TestStand + TestStand Semiconductor Module (2013 - 2020)
NI STS for Mixed signal and RF
(88 Views)
