How to insert (%) in the X and Y scale for XY Scatter chart in excel
I need to insert (%) in the X and Y Scale to the XY scatter Chart (look like the XY Format Axis image). I have tried to use Active X Excel.Axis function (refer to the XY scatter image), but I did not find the format axis for number to insert % in the format code. I also don't know how to select "Select Name in this XY scatter chart (refer to the Select Data image)
(1,894 Views)
Hi Sazila,
Have you tried doing this yet in LabVIEW using the ActiveX controls?
DillonL.
(1,850 Views)
Hi DillonL,
I have tried using Active X-Excel.Axis function. Refer to the Excel.Axis Image below:
Do you have any idea to insert % in the X and Y scale?
(1,841 Views)
