How to input the words Date and Time into the File Format String?
So right now I have a VI in which when you click Save it saves the current state of the Front Panel as a Jpeg. That all works fine. But I wanted to automatically save the file as the current date by using -%y-%d-%H-%M-%S. That also works fine. The only problem? When saved the name of the file looks like a bunch of random numbers.
Ex. 2017-08-28-12-54-19.
Technically this is fine. It's correct. But it looks like crap. Is there a way I can modify the File Format String so that the final file reads "Date: 2017-08-28 Time: 12-54-19"?
Message 1 of 18
(2,045 Views)
Well you probably don't want (or aren't allowed) to have colons in the filename. But there is a function called "format into string". For the format string you can use any words then "%s" as a placeholder. Since your date has 10 characters always, you can just split your string after 10 characters and use "Date %s Time %s" with the first input being your date and the second being time.
Personally, when I collect data during the test it often looks like "20170828_143518_Voltages" for example, and it is easy for me to know the first 8 characters are the date and the next 6 after the underscore are time.
Message 2 of 18
(2,035 Views)
Accepted by ShogunOrta
I typically go with something more like "2017-08-28 12-54-19".  That space makes a good separation between the Date and the Time.  But to answer your question:
GCentral
Message 3 of 18
(2,021 Views)
Is that function you used there a Time Stamp function?
Message 4 of 18
(2,004 Views)
Hey, thanks for that. But....you wouldn't know how to insert a ":" so that the time looks like 14:32:12, rather than 14-32-12?
Message 5 of 18
(1,999 Views)
Hi Orta,
the colon is one of those chars not allowed in filenames...
using LV2020 on Win8.1+cRIO
Message 6 of 18
(1,995 Views)
While the colon ":" is not permitted, oddly enough, the semi-colon ";" is permitted as part of a filename.  Just replace the "-" after the %H and %M with the semicolon ";" for a close visual approximation.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 7 of 18
(1,989 Views)
Yep, that'll work. But I've been looking around the net and have found several examples of Date formatting codes that supposedly give you the current time with colons included. I've tried %T, %t, %X, %x, %Z, %z, and on and on, but nothing works. Does Labview actually have anything like that? Maybe I'm just implementing it wrong.
Message 8 of 18
(1,982 Views)
The default (unwired) is %c. If you want just the time in 24-hour format you can use "%H:%M:%S"
Message 9 of 18
(1,969 Views)
But in "%H:%M:%S", my Labview doesn't seem to accept the colons. I have 2015 though.
Message 10 of 18
(1,964 Views)
