Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
How to initilize a plots origin to (0,0)?
I have a plot in my VI and I want to make sure that everytime that I start the VI that the plots origin is at (0,0). What can I do to initialize it as such?
(3,086 Views)
Create a property node for your plot, and everytime you execute your vi initialize this property node putting it's x0 and y0 values to 0.
Hope this helps
(3,086 Views)
Now are Xo and Yo choices for the property node? I know you can choose from a bunch of properties, which ones do I choose? and so I'd have to attach a control to it? or and indicator?
(3,086 Views)
Sorry it has been a mistake, i meant an attribute node. Right click on the plot, select create>>attribute node, then click on it and select x scale>>x0 and y scale>>y0, then, change them to write and wire a constant to them.
Good luck
(3,086 Views)
Good answer Gorka. Actually, what used to be called "attribute node" in older versions of LabVIEW is called "property node" in version 6i. It sure is confusing. /Mikael
(3,086 Views)
