11-12-2019 10:45 AM
Yes he didn't mention that correctly but logically that's what he meant.
And the ranges are not the point.
Mistakes happen.
11-12-2019 10:48 AM - edited 11-12-2019 10:51 AM
He is a wonderful teacher.
And these common mistakes happen all the time.
i suggest that you don't lose your hope in your teacher for a small mistake.
He is actually a inventer btw.
11-12-2019 10:55 AM
wiebe@CARYA wrote:
@Yamaeda wrote:My C++ teacher lost my respect when she claimed you need a 3rd variable to swap two variables.
Why do you say that? In a text based language, you do need a 3rd variable. Unless there is some other function built into that language that does the swap. I would bet that even then, the underlying machine code probably uses a 3rd register to transfer the values. Please tell me your example of why you claim you would be wrong.
11-12-2019 10:59 AM
You can do it with pointers. It has been way too long since I cared about the specifics, but it was essentially just swapping the addresses in a very weird way.
11-12-2019 11:37 AM
We where not talking about compiler internals.
Just about user declared variables, and how you need a 3rd.
It's fair to say we didn't get along in the first place.
You don't need one, it's comfortable to use one. There's a difference.
Of course there was some conversation first about exactly how utterly impossible it was.
Challenge excepted!
int a = something;
int b = something;
a = a xor b;
b = a xor b;
a = a xor b;
swapped integer values! No 3rd variable!
That proves to me you can most definitely swap to variables without a 3rd.
Reluctantly, see said "but that only works for integers"...
float a = something;
float b = something;
a = a / b;
b = a * b;
a = b / a;
Swapped floats!
She still refused my solution as a possibility, still claiming it was not possible.
There's a difference between "not possible" and "not feasible". Refusing to acknowledge the difference invalidates someone as my programming teacher.
11-12-2019 02:41 PM
Slick.
I was visualizing the classic early programming class example of sorting strings like in a bubble sort and swapping them when needed.
11-13-2019 03:44 AM
Making a mistake is perfectly ok. It's how he'd react to it.
If you point out why the test is confusing (or incomplete), he should say something like: "ah, you're right. I'll fix it for next year". If he responses with: "Bugger off, you're the only one complaining so you must be wrong, stop bugging me", it's a hole other story.
11-13-2019 07:32 AM
wiebe@CARYA wrote:If you point out why the test is confusing (or incomplete), he should say something like: "ah, you're right. I'll fix it for next year". If he responses with: "Bugger off, you're the only one complaining so you must be wrong, stop bugging me", it's a hole other story.
"hole other story." LOL
11-13-2019 07:42 AM
That one wasn't intentional 😊.
