How to increase the row spacing between tree items in a modern tree control
I have a VI where i have used a tree control from the modern pallate, I need to increase the space between tree items. and should be maintained even if I programatically Add or Remove tree items
PS:  "AutoRowHt " Property doesnt seem to help here
(3,445 Views)
Accepted by topic author swpo
Unfortunately I didn't have time to play around with whether or not this propgates to new programmatically created entries in the tree control, but if not, you could always just re-run this section of code (or specify the specific row since you'll know the index of the inserted element).
Specifying -2 into the Row Number property will specify the change is to be made for all rows in the tree.
(3,413 Views)
Thank you 🙂
I shall build my code around this logic  🙂
(3,378 Views)
Necro post but this is the first result from Google. Just commenting to say the above can be used with the property "ActiveItem.Tag" as well.
(I'd incorrectly assumed that the ActiveItem.Row property referred to visible row, but it refers to all rows, whether or not they're visible.)
(161 Views)
