How to increase the data acquisition speed?
Hey, currently I am using NI 6210 for switch control and data acquisiton. I used labview to control 7 switches periodically and read data from 7 channels in the meantime (1 sample on demand). I ran 70 loops to get 10 groups of data, the time cost was like 2.2 seconds.
I would like to finish 700 loops in 2 seconds, is there any way to improve?
Pem
(6,137 Views)
Accepted by pem
Look at the stop terminal of the DAQ Assistant Express VI. You're starting and stopping the DAQ task on every iteration of the loop.
From the help file:
Stop
Specifies to stop the task and release device resources when this Express VI completes execution. For continuous tasks, this input is FALSE by default, meaning the task continues to run until the application stops. To stop the task so you can use the device again in the same application, wire this input to the same stop control you wire to the conditional terminal of the while loop. For single-point and finite tasks, this input is TRUE by default, meaning the task stops after all samples are acquired. To optimize single-point performance when using this Express VI in a loop, wire this input to the same stop control you wire to the conditional terminal of the while loop.
Also from the help file:
For continuous single-point input or output, the DAQ Assistant Express VI might not provide optimal performance. Refer to the Cont Acq&Graph Voltage-Single Point Optimization VI in examples\DAQmx\Analog In\Measure Voltage.llb for an example of techniques to create higher-performance, single-point I/O applications.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(6,120 Views)
The general idea is to set up the daq-task outside the loop as e.g. at 1kHz sample rate, then in the loop, extract 100 samples at a time and work on those. After loop, close the task.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(6,091 Views)
Thanks yall, that do improve a lot.
(6,049 Views)
Hey Kelly- Now I tried to use other sampling method, like N samples (1k samples at rate of 200k). It still cost more than 2 seconds for 10 group data. Any way to speed it up?
Pem
(6,030 Views)
