12-28-2005 12:02 AM - edited 12-28-2005 12:02 AM
Message Edited by Sing-Raven on 12-28-2005 12:04 AM
12-29-2005 10:58 AM
12-29-2011 12:06 PM
HI,
Do you have an IV measurement Vi for a Keithley 6517 , which can reverse the voltage polarity of the voltage source in both directions?
12-29-2011 12:34 PM
@Smahat wrote:
HI,
Instead of hi-jacking a thread from 2005. You should start your own thread. That is ALWAYS better. Hi-jacking older threads are considered bad internet etiquette. So to your problem. Which Labview "driver" are you using? The Labview driver is written in Labview. So it should be no problem in looking at the code and do all modifications that are needed. I think we need more info here. Let us start with you telling us what you have done so far. And why and how you struggle.
Ps Do NOT post pictures of your code. Post the code;)
12-29-2011 04:03 PM
Sorry for that. I am very new to all this. So i just ended up posting on an old thread which I know now is wrong. The thing is I have no knowledge about Labview programming. I was given a ready-to-use VI which uses the Keithley 6517 electrometer to perform an IV sweep within a specified voltage range. The thing is the program can only be used to go from negative voltage to positive at a certain terminal. An error occurs if I want to go from say 50V to -50 V instead of the other way around. Although I have no experience or knowledge of programming in Labview, my professor insisits that I should be able to fix this problem on my own. I have attached the VI. I hope you can help me out here.
Thsnk.
