How to import a csv file into a histogram
Hi, I am looking for a way to be able to import data from a csv file into LabVIEW 8.6 have it create a histogram graph. I have seen this done before, so I know it is possible, I just need some resources are vi's to get me started in the right direction. I have thousands of entries, and it gets teadious importing them vi QI macros. Does anyone know of a vi, or toolbox that will give me the building blocks to do this. Appreciate any help, Thanks, AJ
(5,039 Views)
It is always helpful to provide some information when you ask a question.  If you don't have any code to post, at least tell us which version of LabVIEW you are using.  LabVIEW has a function in the File Palette whose name changed in LabVIEW 2015, but it has a name similar to "Read from Spreadsheet File".  This means "Read from a Something-delimited File" -- in some versions of LabVIEW, it means "comma-delimited", in others it is (by default) "tab-delimited", and you need to set the delimiter to a comma, etc.
There have been numerous examples of using these functions in this Forum.
(5,015 Views)
Accepted by topic author AlphaDog73
Bob,  The OP clearly stated LabVIEW 8.6.
AlphaDog,
Do you have a shortened exaple of you data file?  Are there multiple channels or just one?
Regardless, if you look in the Mathematics->Probability & Statistics palette, you will find a Histogram.vi that will take an array of data and make a histogram out of it.  To display it, use a graph and change the plot type to be a bar chart.
(4,991 Views)
Good point, Crossrulz -- guess I'm just getting "punchy" from seeing so many "how do I do ..." questions when the answers are right there in the LabVIEW Palettes and Help.
BS
(4,955 Views)
Thanks Crossrulz,
The code is basically in a sequence (no state machine here).  There are multiple channels being measured, just one at a time.
Measurements include:
Boolean (T/F)
String (Serial Number, Part Number,etc)
Numrical (DBL)  (Voltage, Current,Resistance)
I have attached a typical csv file we use.
The goal is being able to import these values into histrograms, with upper and lower limits.
See attached,
Once again I appreciate all the help you guys can give me.
See attached,
AJ
(4,899 Views)
Boolean (T/F)
Do you really want a histogram of Booleans?
Do you really want a histogram of Strings?
Unclear which data in Worksheet were Voltage, Current, Resistance
No, you attached an Excel (.xlsx) file.
 What values?  There is a single row of data strung out across >100 columns, with what may be multiple measurements.
Do you have any code of your own to show us?  Are you expecting us to write the code for you?
(4,886 Views)
