How to implement a dual booting PXI system using windows 7 and labview RT
Good Day
My name is Mariano Ocana from the University of Manitoba, and I want to implement a dual system using windows 7 and labview RT in a PXIe-1082 chassis with a PXIe-8102 embedded controlled (the chassis came with windows 7 installed). What are the steps to use both systems (windows and RT)  in the same chassis?, in the NI help comes an example implementing a dual system using windows xp and RT, it is the same procedure?.
Thank you in advance for all your help.
Regards
M. Ocana
(2,257 Views)
Greetings, Mariano.
The real issue you have to contend with is whether or not you have a LabVIEW RT license.  If the 8102 controller was purchased Windows-Only, you likely do not have a license to run LabVIEW RT on the controller - you can purchase one, I think it's about $500, and at that point you can request a LabVIEW RT Configuration CD (that's not what it's called, but the sales guy will know what I'm talking about).  The Config CD is a CD that will partition your controller correctly with both FAT32 and NTFS filesystems (in the appropriate way) to allow you to run Windows 7 and LabVIEW Real-Time on the controller correctly.  Once done, you can then switch within the BIOS between LabVIEW Real-Time and Windows in order to dual-boot.
Either way, you likely need to contact NI sales to either purchase an RT license (if one was not received at the time of purchase) or to request a Configuration CD (it might also be called a dual-boot install CD or similar).
-Danny
(2,247 Views)
