07-03-2019 08:33 PM
I want to do SVR in Labview. I studied the Deep Learning Toolkit, but it seems not support the SVR. Is there any demo or toolkit could achieve it?
07-04-2019 08:54 PM
Recall that LabVIEW is designed as an Engineering Workbench. If you want a lot of analysis routines using a lot of fancy algorithms that you don't want to learn to program yourself, you should check out Mathematics software, such as Matlab or Mathematica.
07-05-2019 03:36 AM
Google "LabVIEW Support Vector Machine" or "LabVIEW Support Vector Regression" gives some promising hits.
It seems IMAQ already can do this, but I'm not sure if it applies to non-image data.
The math itself isn't that scary. If you're into SVR math, it's probably not that hard to make.
