How to identify the correct USB Device in LabVIEW.
Hi LLindenbauer.
Thanks for responding.
That could actually be THE solution, I've been looking for.
Thanks for sharing. I'll look into that in a while.
BR
Bjarne
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
Message 11 of 13
(925 Views)
BCL@Servodan  a écrit :
Hi Defaphe.
Thanks for replying.
Could You backsave that one to LV2019.
Thanks.
BR
Bjarne
Here the link with the file that is ok for older versions.
https://forums.ni.com/t5/LabVIEW/How-to-find-COM-port-for-a-specific-USB-device/m-p/3548364#M993603
Message 12 of 13
(921 Views)
As someone who has both read the USB spec and has been programming LV for over 20 years, I'd recommend finding a function to actually search the enumerated USB devices by PID and VID and use that. Whether it's attached to the hub you want or not is irrelevant for finding the device.
USB is not really meant to be transparent in its "tree" organisation. It's more of a point-to-point bus logically.
Message 13 of 13
(903 Views)
