How to hide a control and change a background image SIMULTANEOUSLY
I have made a slideshow VI on LabView that also monitors real-time data from a datalogger.
The program works like this: -
Startup/Page 1: - Background pane displays a nice screenshot. A set of indicators displays real-time data. Switches to Page 2 after 20 seconds.
Page 2: - Background changes to another screenshot. Real-time indicators hide, and a set of three graphs show up, displaying historical data. Switches after 20s.
Page 3 etc: - Graphs and indicators hide, a 'slideshow' is displayed by changing the background pane. Switches back to page 1 after sequence.
Everything works nicely, except for one thing: I cannot get the indicators to hide and background to change simultaneously, resulting in an awkward 'lag' in between.
I did an example VI to illustrate this. Simply select two separate pictures at the front panel, run the VI and toggle the Boolean control to see what i mean.
Any idea of how to get the indicators and background to change simultaneously?
Thanks in advance,
Jin
(1,365 Views)
Accepted by topic author Jin1987
Hi Jin,
did you try to "DeferPanelUpdates" when doing the switching? It's a property of the pane...
So set Defer=TRUE, do all the switching, set Defer back to FALSE!
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
(1,355 Views)
I would use a tab control and pictures. I would preload the pictures and put the controls on the different pages. See the attached code.
Tim
GHSP
(1,320 Views)
Brilliant, thanks!
(1,296 Views)
