How to get the refresh frequency of all displays
Hi
  My computer have connect two displays, I want to get refresh frequency of all displays. Windows api may be can do this, but i don't know how to use windows api. Does anybody can help me, Thanks.
  LV2017 X64
(2,555 Views)
Here's a .NET API call version in 2015:
This is the following .NET code converted to LabVIEW:
Imports System.Management
    Private Function VideoControllerRefreshRate() As String
        Dim refreshRate As String = Nothing
        Dim query As New SelectQuery("Win32_VideoController")
        Using managementObjectSearcher As New ManagementObjectSearcher(query)
            Using managementObjectSearcherResults = managementObjectSearcher.Get() _
                                                    .Cast(Of ManagementObject)() _
                                                    .FirstOrDefault()
                If managementObjectSearcherResults IsNot Nothing Then
                    refreshRate = managementObjectSearcherResults("CurrentRefreshRate").ToString
                End If
            End Using
        End Using
        Return refreshRate
    End Function
Originally found here.
Small note: I only have a 1-monitor system to test on, but in theory it should work for any amount.  It's not tested on more than one though.
(2,522 Views)
