10-03-2018 05:11 PM
I'm working with LabVIEW FPGA module using a NI-9146 chassis and NI-9234 sound and vibration module. I'm trying to set the Input Configuration for Analog Input channels in the FPGA VI. I looked up the NI 9234 example and found this "integrated" FPGA I/O Property Node. But I can't find this function in any palette. I want to use it as it's compact and easy to use. How can I get it? Attached is a screen capture of it.
The FPGA palette has the generic Property Node to which I need to connect an I/O constant.
Solved! Go to Solution.
10-03-2018 05:21 PM
10-04-2018 10:47 AM
Thank you!
02-01-2019 03:35 PM
Yeah, wow thank you...Why is that much harder than it needs to be. I am pretty familiar with RT/FPGA and it's not obvious- as your final selection from the mouse fly-out menu is the channel 'data' and then it changes to the module config when it appears on the diagram.
Regards
Jack
