How to get the index of a pressed button in control array?
Greetings,
I have 3 parallel arrays--one containing buttons and the other two containing string indicators.  I'd like to be able to push a button and get the values in the other arrays.  How can this be done?
(P.S.  Illustrations are great and most welcome, but I do not have Labview on this computer, so I would appreciate it in jpg or screenshots if possible.)
Thank you!
Message 1 of 8
(33,640 Views)
Instead of an array of Booleans, you should use a radio control if you only want one of the buttons to be true. The output would be wired directly to an Index Array function.
Message 2 of 8
(33,633 Views)
Use an event structure for a value change of the boolean array.
Do a "not equal" comparison on the "new value" and "old value" event terminal, the use "search array" on the result to find the TRUE element. The output will be the index of the changed element. If you want latch action, reset the boolean array control to all false using a local variable.
Message 3 of 8
(33,626 Views)
Here's what I had in mind. Modify as needed.
Message 4 of 8
(33,618 Views)
Accepted by newbo
If you have the buttons initalized to all false, then you don't need to perform the Not Equal To.  Just do a search with the NewVal.  The local variable to reset the buttons should be wired to the OldVal.
Message 5 of 8
(33,612 Views)
Currently, the button array stays on the selected element for positive user feedback. Immediately resetting to false might confuse the user and we would need another indicator to show which was was pressed last.
(Your method is a bit dangerous in the general case, where e.g. several buttons could get changed at the same time from elsewhere in the program via locals.) Still, I agree my code is only one of many possible ways to do this.
Message 6 of 8
(33,606 Views)
Ah, I see what you're doing with it now.  The only problem would be if somebody deselected the button.
Yes, my implementation was with the assumption that that was the only code affecting the value.
Message 7 of 8
(33,602 Views)
My current implementation does not allow deselection. If the user tries, that button is detected as changed and will be set true again immediately. All this can easily be fine tuned as needed.;)
Message 8 of 8
(33,589 Views)
