How to get select information back from tree view active X control?
I am using activeX control of MS tree view. I could add items. however, I would like to know which item is selected when it is highlighted by mouse. I try several properties (such drophighling, selected,..), they could not give me any information back.
Any suggestion? Thanks.
(2,327 Views)
The best place to find information about Microsoft activeX controls is the MSDN. Normally, we would point you there, but I played with your program and got it to select. The problem is that your activeX container was an indicator. It is attached below and was saved in LV6.1.
Jeremy Braden
(2,327 Views)
