Hello
i have a speech signal which i need to process. I have estimated its DC-offset (using the AC-DC estimate vi) to be approximately 126 V. I have read some posts here that some reccomend to just subtract this value from the array of data or use a filter to do it. What is the difference, which one should perform better? I have also broke down my initial array of 50000 samples into sub-arrays of 512. Where should be the best place to get rid of the DC? Once and out from the initial array or later on from the subarrays?
When someone says subtact that value (DC value) from the signal, what exactly has to be done?
When using a filter, what shall i be looking for to do?Specifications of it?
Any help is appreciated
