How to get numerical indicator outside loop and sub.vi
I have a vi which I want to output a counter value to the panel.  I can get the output to the panel but not when I use it as a sub vi, the value only gets written after the sub vi is done executing.  How can I get the numerical indicator to display constant while the sub vi is running.  I think global variables and/or property nodes may work but I have no idea how to set one up evan after looking at examples.
Message 1 of 8
(6,073 Views)
Use a control reference. You can pass in a reference to the indicator to the subVI, and the subVI can write the value. See attached example. You can read more about control references in the LabVIEW Help. There are also shipping examples (Help -> Find Examples).
Message 2 of 8
(6,063 Views)
In addition, your code has some other problems:
  • Place the "sweep complete" indicator in the inner loop, eliminating the local.
  • The outer FOR loop has no purpose, delete it.
  • The inner loop needs a small wait. You don't need to check for completion evey nanosecond and consume all CPU doing so.
Message 3 of 8
(6,047 Views)
Ok I am still confused.  I have added the node I think correctly.  But I guess I am doing something wrong because the sub.vi cause wiring errors.  I think the local variable was done because of the same thing that I wanted sweep complete it light outside of loop.
Message 4 of 8
(6,038 Views)
Hi drew,
you only have to wire a reference to the indicator in the main vi!
Some more notes:
- Instead of running a FOR loop 0 or 1 time you should really use a case structureSmiley Wink
- Use some left-to-right wiring, helps reading your vi a lot!
- Use error clusters to avoid all those stacked sequences!
Message 5 of 8
(6,033 Views)
Ok so I checked the vi you gave.  It still does the same things.  THe indicator in the main program doesn't show the angle til the sub.vi is finished completly.  So it jumps from -75 to -71.  It doesn't count down as the anlge changes.
Message 6 of 8
(6,023 Views)
Hi drew,
you have to wire a reference to the indicator in the main vi!!!
Your subvi has a reference input, but nothing is wired here - so how should the subvi know which reference to take? By pure guessing?
Message 7 of 8
(6,021 Views)
I thought my example was fairly straightforward? Smiley Surprised
Message Edited by smercurio_fc on 07-01-2008 04:38 PM
Message 8 of 8
(6,003 Views)
