How to get frequency at Max amplitude
I m acquiring a waveform from the DAC which as a maximum amplitude at a some frequency. I want to use that frequency at which the max amplitude is seen  for further processing. Now how can I detect the frequency at maximum amplitude ?
(2,854 Views)
Try the Waveform Peak Detection.vi under programming>>waveform>>analog waveform>>waveform measurements>>waveform monitoring.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,844 Views)
Hi micro,
your post is not fully clear to me...
It seems you need some FFT operation to get the max frequency peak.
Otherwise it makes no sense to ask for a frequency at a certain amplitude peak...
(2,838 Views)
You could try the Extract Single Tone Information vi (or the Extract Multiple Tone Information vi) in the waveform measurements palette.  The single tone version will find the frequency with the highest amplitude.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(2,826 Views)
