How to get feed back signal in LabVIEW
Dear friends,
I am not getting the required waveform in LabVIEW. I designed a model in MATLAB and recreated the same in LabVIEW. I am not getting the result in LabVIEW. I have attached the pic of the simulink model in MATLAB and the result obtained for the same. But  I am finding some difficulty in getting the same result for the same model in LabVIEW. I have attached the VI. Please help me regarding this.
Thank You
Message 1 of 22
(249 Views)
Hi prasad,
The resulting waveform looks very similar to the one shown in Screenshot24.
So what is your "difficulty"?
CLAD expired, using 2009SP1 + LV2011SP1 + LV2017 (+LV2018 sometimes) on Win7+cRIO
Kudos are welcome Smiley Wink
Message 2 of 22
(228 Views)
Dear Sir,
The Amplitude of the waveform is not matching in both cases. The first feedback which is a multiplication of 0 and 4.885364 is giving some problem i think. Please suggest the any modification.
Message 3 of 22
(219 Views)
Hi prasad,
you should cleanup and simplify the block diagram:
Are you sure all those constants are correctly typed in and wired?
Message 4 of 22
(206 Views)
Yes Sir,
I have Entered Constants correctly. But When i use only one exponential loop i wont get the result at all. I have attached Both MATLAB and LabVIEW results.
Message 5 of 22
(155 Views)
Hi prasad,
your older VI still runs, even after moving most (?) constant operations out of the loop:
Your new VI looks different, so I guess your formulas are wrong now…
Message 6 of 22
(140 Views)
Dear sir,
I actually need the result from new VI i have sent. I checked the formulas and constants. only the multiplication with 0 and 4.88564 is giving problem ( I HAVE MENTIONED IN the same in the attached VI). further multiplication like 2 and 4.88564 are working fine. it is actually a increment from 0 to 2.
0x4.88564(which is not working) 1x4.88564(which is working)
2x4.88564(which is working)
Hope you got my point.
Message 7 of 22
(125 Views)
Hi prasad,
Why do you think so?
I always get the expected result of zero for this (Rube-Goldberg) operation!
Message 8 of 22
(120 Views)
I have attached an image.
Here the red circle loop is not giving result (0x4.88564)
where as the green circle will give the result. (1x4.88564) followed by (2x4.88564)
That is why i sent new VI with only one loop multiplication of 0 and 4.88564
Thank You
Message 9 of 22
(117 Views)
the result should not be 0 for 0x4.88564 case. The result required should be same as the MATLAB result as i have attached the pic of the same.
Message 10 of 22
(112 Views)
