08-13-2019 04:20 AM
Dear friends,
I am not getting the required waveform in LabVIEW. I designed a model in MATLAB and recreated the same in LabVIEW. I am not getting the result in LabVIEW. I have attached the pic of the simulink model in MATLAB and the result obtained for the same. But I am finding some difficulty in getting the same result for the same model in LabVIEW. I have attached the VI. Please help me regarding this.
Thank You
08-13-2019 04:51 AM
08-13-2019 05:07 AM
Dear Sir,
The Amplitude of the waveform is not matching in both cases. The first feedback which is a multiplication of 0 and 4.885364 is giving some problem i think. Please suggest the any modification.
08-13-2019 05:41 AM
08-13-2019 07:58 AM
Yes Sir,
I have Entered Constants correctly. But When i use only one exponential loop i wont get the result at all. I have attached Both MATLAB and LabVIEW results.
08-13-2019 08:18 AM - edited 08-13-2019 08:19 AM
08-13-2019 08:45 AM
Dear sir,
I actually need the result from new VI i have sent. I checked the formulas and constants. only the multiplication with 0 and 4.88564 is giving problem ( I HAVE MENTIONED IN the same in the attached VI). further multiplication like 2 and 4.88564 are working fine. it is actually a increment from 0 to 2.
0x4.88564(which is not working) 1x4.88564(which is working)
2x4.88564(which is working)
Hope you got my point.
08-13-2019 08:49 AM
08-13-2019 08:53 AM
I have attached an image.
Here the red circle loop is not giving result (0x4.88564)
where as the green circle will give the result. (1x4.88564) followed by (2x4.88564)
That is why i sent new VI with only one loop multiplication of 0 and 4.88564
Thank You
08-13-2019 08:58 AM
the result should not be 0 for 0x4.88564 case. The result required should be same as the MATLAB result as i have attached the pic of the same.
